HomeHome  PortalPortal  FAQFAQ  SearchSearch  RegisterRegister  MemberlistMemberlist  UsergroupsUsergroups  Log inLog in
 Solar systems: An effective way to cut down the heating bill
AdenTamerlane
Number of posts : 1
Registration date : 2011-05-10
PostSubject: Solar systems: An effective way to cut down the heating bill   Tue May 10, 2011 6:29 am
A solar hot water system is really a great benefit to those who are searching for methods to reduce their dependency upon non-renewable fuels, especially for the purpose of heating water and electricity. A large amount of your electricity or perhaps gas a family utilizes goes towards heating water. You could do a lot more important stuff if you could save the money you spend on merely heating water.
Solar hot water systems accumulate thermal power from the sunshine and utilize it to help heat water as a substitute for utilizing electricity and even gas. There are numerous solar systems qld companies who can install a hot water system for your home depending upon your needs.
An essential component of such type of method is insulating heat transportation pipes. Solar hot water systems have a very good built-in device in order to be certain that the water inside the container doesn't over-heat on times of extreme solar radiation. That device consists of discharging hot water out of your water tank as soon as the temperature reaches boiling point - a normal situation on a hot summer day.
Solar hot water systems could be over 3 times extremely effective compared with photovoltaic systems regarding converting the sun's radiation into energy you can utilize at your house.
As well as in a number of regions, hot water heaters are often the second or 3rd largest energy drain at your house (after cooling and heating), and this may result in major savings. So it would be a wise idea to get a solar systems qld firm to install a solar system at your home.
Mr. F
Number of posts : 1216
Where I am : san diego
Registration date : 2007-01-25
PostSubject: Re: Solar systems: An effective way to cut down the heating bill   Thu May 26, 2011 9:10 pm
We already have a solar system - Mercury, Venus, Earth, Mars, Jupiter, Uranus, Neptune, and Pluto (if its still called a planet), so I dont see how installing another one would be a good idea
Nymphadora
Number of posts : 4023
Where I am : North Carolina
Registration date : 2007-01-23
PostSubject: Re: Solar systems: An effective way to cut down the heating bill   Tue May 31, 2011 3:08 am
Pluto is a dwarf planet. Wait, is that PC or should we call it a little planet? I'm not sure.
Maybe Pluto being downgraded has cause some adverse effect on energy cost. So really we must add a new solar system to make up for it. Must have something to do with gravity or some other nerdishness.
What really caught my eye was this line "As well as in a number of regions, hot water heaters are often the second or 3rd largest energy drain at your house..." No kidding with that huh. I mean water heaters are bad enough but I've never understood hot water heaters. Why pay so much money to heat your hot water, exactly how hot does your water need to be?
Page 1 of 1
» Theory: More Solar System Senshi?
» Solar powered lights
» Big Truck Air Brake Systems
» Kickstarter: Battle Systems™ Sci-fi Modular Terrain
» Pokemon Solar Light and Lunar Dark!
Inrejects :: General Discussion :: General Chit Chat-
